Toon onderwerp - Userplugin • nodo-domotica.nl
Userplugin
Re: Userplugin
Berichtdoor mvdbro » 29 dec 2012, 16:40
Re: Userplugin
Berichtdoor mvdbro » 30 dec 2012, 15:58
Update Userplugin 0.15.0.
Recente release notes:
0.13.0 - Splitsing in losse bestanden, calls naar sub plugins
0.13.3 - Mini MMI bugfix voor nieuwe "Nodotool"
0.13.4 - Mini MMI bugfix voor newkaku/kaku
0.13.5 - nieuwe define UP_DEBUG, om meer ruimte te winnen (tbv Small)
0.14.0 - nieuwe sub plugin, "sleep" via userplugin 225,<sleeptime> (tbv batterijvoeding)
0.15.0 - RFID plugin voorzien van LCD berichten, LCD boot melding voorzien van versie en unit id
(Hmm, recht fotograferen is ook een vak apart :( )
Download:
Re: Userplugin
Berichtdoor mvdbro » 06 jan 2013, 17:12
Update Userplugin collectie. Release notes zitten vanaf nu in de zipfile. Aangezien mijn dropbox account vol ging lopen heb ik alles verplaatst naar google code (weer 4 GB gratis opslag..)
Re: Userplugin
Berichtdoor Twan » 10 mei 2013, 15:59
Ik probeer de userplugin 0.19.0 mee te compileren, maar krijg de volgende foutmeldingen:
User_Plugin.ino: In function 'void UserPlugin_Init()':
User_Plugin:35: error: redefinition of 'void UserPlugin_Init()'
UserPlugin_Base:121: error: 'void UserPlugin_Init()' previously defined here
User_Plugin.ino: In function 'void UserPlugin_Command(int, int)':
User_Plugin:49: error: redefinition of 'void UserPlugin_Command(int, int)'
UserPlugin_Base:163: error: 'void UserPlugin_Command(int, int)' previously defined here
User_Plugin.ino: In function 'boolean UserPlugin_Receive(long unsigned int)':
User_Plugin:83: error: redefinition of 'boolean UserPlugin_Receive(long unsigned int)'
UserPlugin_Base:215: error: 'boolean UserPlugin_Receive(long unsigned int)' previously defined here
User_Plugin.ino: In function 'void UserPlugin_Periodically()':
User_Plugin:104: error: redefinition of 'void UserPlugin_Periodically()'
UserPlugin_Base:251: error: 'void UserPlugin_Periodically()' previously defined here
User_Plugin.ino: In function 'long unsigned int RawSignal_2_UserPlugin(int)':
User_Plugin:151: error: redefinition of 'long unsigned int RawSignal_2_UserPlugin(int)'
UserPlugin_Base:275: error: 'long unsigned int RawSignal_2_UserPlugin(int)' previously defined here
De versie van de nodo software waarin ik deze userplugin mee probeer te compileren is V3.01 Build 491. Er is niets gewijzigd in de sketches, zowel de nodo software als de userplugin worden gecompileerd zoals ze gedownload zijn.
Weet iemand mij aangeven wat hier mis gaat?
Gr. Twan.
Twan
Geregistreerd: 17 jan 2013, 21:08
Re: Userplugin
Berichtdoor mvdbro » 10 mei 2013, 16:15
Zo te zien heb je de originele user_plugin.ino er ook nog bij staan, dat bestand moet je verwijderen.
Bedenk wel dat het userplugin concept in de nieuwe Nodo release niet meer beschikbaar is!
Re: Userplugin
Berichtdoor Twan » 10 mei 2013, 16:26
Martinus,
Dank je wel, dat was de gouden tip! Ik ben me ervan bewust dat het userplugin concept gaat vervallen. Ik wil echter even testen met de PWM plugin voor het aansturen van LED spots. Is het wel mogelijk om de Node1 op de laatste nodo versie te laten werken, en een nodo unit 2 op een oudere versie bv voor het aansturen van leds met de pwm plugin?
Gr. Twan.
Twan
Re: Userplugin
Berichtdoor mvdbro » 10 mei 2013, 16:40
Re: Userplugin
Berichtdoor manjh » 11 mei 2013, 12:39
Re: Userplugin
Berichtdoor BasPost » 01 aug 2013, 08:18
BasPost
Woonplaats: Tolkamer
Keer terug naar Nodo Software
