Output=RF, Unit=6, Event=PulseCount 4
Output=RF, Unit=6, Event=WiredAnalog 1,702
Output=RF, Unit=6, Event=WiredIn 1,On
Input=Wired, Unit=6, Event=WiredIn 1,Off
Input=Wired, Unit=6, Event=WiredIn 1,On
Internal=Variables, Unit=6, Event=Variable 2,4.00
Internal=Timers, Unit=6, Event=Timer 1
Output=RF, Unit=6, Event=PulseTime 6873
Output=RF, Unit=6, Event=PulseCount 3
Output=RF, Unit=6, Event=WiredAnalog 1,686
Output=RF, Unit=6, Event=WiredIn 1,Off
Internal=Variables, Unit=6, Event=Variable 2,5.00
Internal=Variables, Unit=6, Event=Variable 2,6.00
Output=RF, Unit=6, Event=PulseTime 6911
Output=RF, Unit=6, Event=WiredAnalog 1,699
Internal=Variables, Unit=6, Event=Variable 2,7.00
! Slave 6 meterkast versie 007
sendto 6; EventlistErase
sendto 6; EventlistWrite; WildCard RF,All; SendEvent HTTP
sendto 6; EventlistWrite; WildCard Variables,All; SendEvent HTTP
! BPW40 Stroom meter 480/kwh
sendto 6; EventlistWrite; Boot 6; TimerSetsec 1,20
sendto 6; EventlistWrite; Timer 1; TimerSetsec 1,20
sendto 6; EventlistWrite; Timer 1; status pulsetime
sendto 6; EventlistWrite; Timer 1; status pulsecount
sendto 6; EventlistWrite; Timer 1; PulseCount 0
! De cny70 heb ik op een analoge ingang 1 gezet. Gas meter
sendto 6; EventlistWrite; WiredThreshold 1,696;
sendto 6; EventlistWrite; WiredSmittTrigger 1,5;
sendto 6; EventlistWrite; Timer 1; Status WiredAnalog 1;
sendto 6; EventlistWrite; Timer 1; Status WiredIn 1;
sendto 6; EventlistWrite; WiredIn 1,on; VariableInc 2,1;
sendto 6; EventListWrite; Variable 2, 100.0; VariableSet 2, 0.00;
Output=RF, Unit=6, Event=PulseTime 1401
Output=RF, Unit=6, Event=PulseCount 15
Output=RF, Unit=6, Event=WiredAnalog 1,586
Output=RF, Unit=6, Event=WiredAnalog 2,850
Output=RF, Unit=6, Event=WiredIn 2,Off
Input=Wired, Unit=6, Event=WiredIn 2,On
Internal=Variables, Unit=6, Event=Variable 3,3.00
! Slave 6 meterkast versie 0089
! commando SendBusy Off onder command gebruikt
! wiredanalog 1 is een CNY70 op de gasmeter
! wiredanalog 2 is een CNY70 op de watermeter
! poort 18 mega2560 BPW40
! WiredThreshold (standaard 512)
! CNY70 analoge ingang 1, Gas meter
sendto 6; EventlistWrite; Boot 6; WiredThreshold 1,694;
! CNY70 analoge ingang 1, Water meter
sendto 6; EventlistWrite; Timer 1; Status WiredAnalog 2;
sendto 6; EventlistWrite; Timer 1; Status WiredIn 2;
sendto 6; EventlistWrite; WiredIn 2,on; VariableInc 3,1;
sendto 6; EventListWrite; Variable 3, 100.0; VariableSet 3, 0.00;
! Slave 6 meterkast versie 010
sendto 6; EventlistWrite; WildCard Variables,All; SendEvent RF
sendto 6; EventlistWrite; Boot 6; TimerSetsec 1,30
sendto 6; EventlistWrite; Timer 1; TimerSetsec 1,30
sendto 6; EventlistWrite; delay 1
sendto 6; EventlistWrite; Boot 6; TimerSetsec 2,60
sendto 6; EventlistWrite; Timer 2; TimerSetsec 2,60
sendto 6; EventlistWrite; Timer 2; Status WiredAnalog 1;
sendto 6; EventlistWrite; Timer 2; Status WiredIn 1;
sendto 6; EventlistWrite; WiredIn 1,on; VariableInc 1,1;
sendto 6; EventListWrite; Variable 1, 100.0; VariableSet 1, 0.00;
! CNY70 analoge ingang 2, Water meter
sendto 6; EventlistWrite; Boot 6; WiredThreshold 2,625;
sendto 6; EventlistWrite; WiredSmittTrigger 2,5;
sendto 6; EventlistWrite; Timer 2; Status WiredAnalog 2;
sendto 6; EventlistWrite; Timer 2; Status WiredIn 2;
sendto 6; EventlistWrite; WiredIn 2,on; VariableInc 2,1;
Gasmeter webapp Dag verbruik:
Pulsecount
Value
NO
Electra per dag (prefix)
Kw/w (suffix)
6 (unit)
168 (graph)
%value% /480 (formula)
2 (round)
Gasmeter webapp Actueel verbruik
Pulstime
Value
NO
Electra actueel (prefix)
Watt (suffix)
6 (unit)
Line (graph)
24 (graph max hours)
7500 / %value% * 1000 (formula)
2 (round)
Slave 6 meterkast versie 011
sendto 6; EventlistWrite; Boot 6; TimerSetsec 1,30;
sendto 6; EventlistWrite; Timer 1; TimerSetsec 1,30;
sendto 6; EventlistWrite; Timer 1; status pulsetime;
sendto 6; EventlistWrite; delay 1;
sendto 6; EventlistWrite; Timer 1; status pulsecount;
sendto 6; EventlistWrite; Timer 1; PulseCount 0 ;
sendto 6; EventlistWrite; Boot 6; TimerSetsec 2,60;
sendto 6; EventlistWrite; Timer 2; TimerSetsec 2,60;
sendto 6; EventlistWrite; Boot 6; WiredThreshold 1,625;
sendto 6; EventlistWrite; WiredIn 1,Off; VariableSet 1,0.00;
sendto 6; EventlistWrite; WiredIn 1,On; VariableSet 1,1.00;
sendto 6; EventListWrite; Variable 1,100.0; VariableSet 1,0.00;
sendto 6; EventlistWrite; Boot 6; WiredThreshold 2,700;
sendto 6; EventlistWrite; WiredIn 2,Off; VariableSet 2,0.00;
sendto 6; EventlistWrite; WiredIn 2,On; VariableSet 2,1.00;
sendto 6; EventListWrite; Variable 2,100.0; VariableSet 2,0.00;
Internal=Variables, Unit=6, Event=Variable 2,1.00
Output=RF, Unit=6, Event=Variable 2,1.00
Internal=Variables, Unit=6, Event=Variable 2,2.00
Output=RF, Unit=6, Event=Variable 2,2.00
Input=Wired, Unit=6, Event=WiredIn 2,Off
Internal=Variables, Unit=6, Event=Variable 2,0.00
Output=RF, Unit=6, Event=Variable 2,0.00
Internal=Variables, Unit=6, Event=Variable 1,1.00
Output=RF, Unit=6, Event=Variable 1,1.00
Internal=Variables, Unit=6, Event=Variable 1,2.00
Output=RF, Unit=6, Event=Variable 1,2.00
Internal=Variables, Unit=6, Event=Variable 1,0.00
Output=RF, Unit=6, Event=Variable 1,0.00
Output=RF, Unit=6, Event=PulseTime 6746
Output=RF, Unit=6, Event=PulseCount 5
Internal=Timers, Unit=6, Event=Timer 2
Output=RF, Unit=6, Event=WiredAnalog 1,589
Output=RF, Unit=6, Event=WiredAnalog 2,506
Output=RF, Unit=6, Event=PulseTime 7273
Output=RF, Unit=6, Event=PulseTime 8172
Output=RF, Unit=6, Event=WiredAnalog 1,593
Output=RF, Unit=6, Event=WiredAnalog 2,508
Output=RF, Unit=6, Event=PulseTime 8127
Output=RF, Unit=6, Event=PulseTime 8270
Output=RF, Unit=6, Event=WiredAnalog 1,591
Output=RF, Unit=6, Event=PulseTime 8317
Output=RF, Unit=6, Event=PulseTime 9452
Output=RF, Unit=6, Event=WiredAnalog 2,484
Output=RF, Unit=6, Event=PulseTime 9588
Output=RF, Unit=6, Event=PulseTime 9570
Output=RF, Unit=6, Event=WiredAnalog 1,594
Output=RF, Unit=6, Event=WiredAnalog 2,515
Output=RF, Unit=6, Event=PulseTime 9608
Output=RF, Unit=6, Event=PulseTime 9484
Output=RF, Unit=6, Event=WiredAnalog 2,514
Output=RF, Unit=6, Event=PulseTime 9163
Output=RF, Unit=6, Event=PulseTime 9553
