Toon onderwerp - R743 eventlist laadt niet volledig • nodo-domotica.nl
Berichtdoor Annie » 22 maart 2014, 21:05
Hallo!
Als ik mijn eventlist in R743 probeer te laden, dan wordt deze niet volledig opgeslagen. Eventlist:
EventlistErase
EventlistWrite; Time 00:00,*; ClockSync
EventlistWrite; NewKAKU 0xD60682,On; NewKAKUSend 5,On
EventlistWrite; NewKAKU 0xD60682,Off; NewKAKUSend 5,Off
EventlistWrite; NewKAKU 0xD4F2182,On; NewKAKUSend 5,On
EventlistWrite; NewKAKU 0xD4F2182,Off; NewKAKUSend 5,Off
EventlistWrite; NewKAKU 0xD60681,On; NewKAKUSend 6,On
EventlistWrite; NewKAKU 0xD60681,Off; NewKAKUSend 6,Off
EventlistWrite; NewKAKU 0xD4F2181,On; NewKAKUSend 6,On
EventlistWrite; NewKAKU 0xD4F2181,Off; NewKAKUSend 6,Off
EventlistWrite; NewKAKU 0xD4F2180,On; NewKAKUSend 4,On
EventlistWrite; NewKAKU 0xD4F2180,Off; NewKAKUSend 4,Off
EventlistWrite; NewKAKU 0xD60680,On; NewKAKUSend 4,On
EventlistWrite; NewKAKU 0xD60680,Off; NewKAKUSend 4,Off
EventlistWrite; NewKAKU 0xD4F2183,On; NewKAKUSend 2,On
EventlistWrite; NewKAKU 0xD4F2183,Off; NewKAKUSend 2,Off
EventlistWrite; NewKAKU 0xD60683,On; NewKAKUSend 2,On
EventlistWrite; NewKAKU 0xD60683,Off; NewKAKUSend 2,Off
EventlistWrite; NewKAKU 0xD60684,On; NewKAKUSend 3,On
EventlistWrite; NewKAKU 0xD60684,Off; NewKAKUSend 3,Off
EventlistWrite; NewKAKU 0xD4F2184,On; NewKAKUSend 3,On
EventlistWrite; NewKAKU 0xD4F2184,Off; NewKAKUSend 3,Off
EventlistWrite; UserEvent 100,1; VariableSet 1,1.00
EventlistWrite; UserEvent 100,1; NewKAKUSend 7,On
EventlistWrite; UserEvent 100,2; VariableSet 1,0.00
EventlistWrite; UserEvent 100,2; NewKAKUSend 7,Off
EventlistWrite; NewKAKU 0xE0B2B89,On; BreakOnVarEqu 1,1.00
EventlistWrite; NewKAKU 0xE0B2B89,On; BreakOnDaylight On
EventlistWrite; NewKAKU 0xE0B2B89,On; TimerSet 1,300
EventlistWrite; NewKAKU 0xE0B2B89,On; NewKAKUSend 7,On
EventlistWrite; NewKAKU 0xE0B2B89,Off; BreakOnVarEqu 1,1.00
EventlistWrite; NewKAKU 0xE0B2B89,Off; BreakOnDaylight On
EventlistWrite; NewKAKU 0xE0B2B89,Off; TimerSet 1,300
EventlistWrite; NewKAKU 0xE0B2B89,Off; NewKAKUSend 7,On
EventlistWrite; Timer 1; NewKAKUSend 7,Off
EventlistWrite; UserEvent 101,1; WiredOut 1,On
EventlistWrite; UserEvent 101,2; WiredOut 1,Off
EventlistWrite; UserEvent 102,1; WiredOut 2,On
EventlistWrite; UserEvent 102,2; WiredOut 2,Off
EventlistWrite; Time 22:00,*; UserEvent 102,2
EventlistWrite; ClockDaylight 4,0; NewKAKUSend 8,On
EventlistWrite; ClockDaylight 2,0; NewKAKUSend 8,Off
EventlistWrite; RFIDWG 0,0x9F6F6F; VariableInc 2,1.00
EventlistWrite; RFIDWG 0,0x8CAC3F; VariableInc 2,1.00
De volgende regels ongeveer hierna worden niet opgeslagen in de eventlist:
EventlistWrite; RFIDWG 0,0x1DE0A1; VariableInc 2,1.00
EventlistWrite; RFIDWG 0,0x93EDFC; VariableInc 2,1.00
EventlistWrite; RFIDWG 0,0x566674; VariableInc 2,1.00
EventlistWrite; RFIDWG 0,0x93C0D6; VariableInc 2,1.00
EventlistWrite; RFIDWG 0,0x565AAC; VariableInc 2,1.00
EventlistWrite; RFIDWG 0,0x547685; VariableInc 2,1.00
EventlistWrite; RFIDWG 0,0x8DB574; VariableInc 2,1.00
EventlistWrite; RFIDWG 0,0x2CADAB; VariableInc 2,1.00
EventlistWrite; RFIDWG 0,0x33BD8F; VariableInc 2,1.00
EventlistWrite; Variable 2,1.00; Sound 5,1
EventlistWrite; Variable 2,1.00; UserEvent 104,1
EventlistWrite; Variable 2,2.00; VariableSet 2,0.00
EventlistWrite; Variable 2,0.00; Sound 5,1
EventlistWrite; Variable 2,0.00; UserEvent 104,2
EventlistWrite; Variable 2,0.00; TimerSet 2,0
EventlistWrite; NewKAKU 0xD60685,On; UserEvent 105,1
EventlistWrite; UserEvent 105,1; BreakOnVarEqu 2,0.00
EventlistWrite; UserEvent 105,1; Sound 3,5
EventlistWrite; UserEvent 105,1; TimerSet 2,15
EventlistWrite; Timer 2; UserEvent 103,1
EventlistWrite; Timer 2; Sound 6,1
EventlistWrite; UserEvent 104,1; BreakOnVarEqu 2,1.00
EventlistWrite; UserEvent 104,1; VariableSet 2,1.00
EventlistWrite; UserEvent 104,2; BreakOnVarEqu 2,0.00
EventlistWrite; UserEvent 104,2; VariableSet 2,0.00
EventlistWrite; UserEvent 104,2; TimerSet 2,0
Weet iemand waarom de eventlist niet helemaal wordt opgeslagen? In R596 doet-ie het wel. In die versie doen de rookmelderplugins het echter niet, die komen dan niet door de compiler......
Groetjes,
André
Annie
Re: R743 eventlist laadt niet volledig
Berichtdoor henkdejonge » 23 maart 2014, 09:45
Ik heb dit ook wel eens gehad en heb toen de eventlist via een puttysessie naar binnen geloodst. Gewoon je eventlist kopieeren. En dan plakken in je puttysessie. Even wachten en dan zit tie erin.
Grtz,
Henk.
henkdejonge
Berichtdoor Annie » 23 maart 2014, 10:12
Hallo Henk;
Dankjewel voor je reactie, ga dat vanavond als ik weer thuis ben proberen!
André
Annie
Berichtdoor Annie » 23 maart 2014, 18:15
Ha die Henk;
Heb de eventlist inderdaad met Putty kunnen inladen! Nu dus lekker verder testen met R744!
Bedankt!!!!!! :shock:
André
Annie
