eventlisterase;
! close marquises at sundown
eventlistwrite; ClockDaylight 4,0; FileExecute 201,Off
! close marquises at sundown plus 5 minutes (get rid of stuck frames)
eventlistwrite; ClockDaylight 4,0; Timerset 6,300
eventlistwrite; Timer 6; FileExecute 201,Off
! this will send all inbound rf info to the webserver.
eventlistwrite; WildCard RF,All,0; EventSend HTTP
! next make remotes open and close all marquises
eventlistwrite; Kaku C3,On; FileExecute 200,Off
eventlistwrite; Kaku C3,Off; FileExecute 201,Off
!enno's kamer
eventlistwrite; Kaku C1,On; NewKAKUSend 127,On
eventlistwrite; Kaku C1,Off; NewKAKUSend 127,Off
!LICHT in de bijkeuken achterin
eventlistwrite; kaku C0,on; NewKAKUsend 201, on
eventlistwrite; kaku C0,off; NewKAKUsend 201, off
!LICHT bibliotheek
eventlistwrite; kaku C4,on; NewKAKUsend 3, on
eventlistwrite; kaku C4,off; NewKAKUsend 3, off
! read all vars and send them to nodo
! initiate alecto 3500
EventlistWrite; Boot 5; AlectoV1 77,1
EventlistWrite; Boot 5; AlectoV1 169,1
! set timer for data sending
EventlistWrite; Boot 5; TimerSet 1,120
EventlistWrite; Timer 1; TimerSet 1,120
EventlistWrite; Timer 1; DHTRead 1,7
EventlistWrite; Timer 1; VariableSend 1,HTTP
EventlistWrite; Timer 1; VariableSend 2,HTTP
EventlistWrite; Timer 1; VariableSend 3,HTTP
EventlistWrite; Timer 1; VariableSend 4,HTTP
EventlistWrite; Timer 1; VariableSend 5,HTTP
EventlistWrite; Timer 1; VariableSend 6,HTTP
EventlistWrite; Timer 1; VariableSend 7,HTTP
EventlistWrite; Timer 1; VariableSend 8,HTTP
! Check every 20 seconds for rain
! set timer 2 for every 20 seconds
EventlistWrite; Boot 5; TimerSet 2,20
EventlistWrite; Timer 2; TimerSet 2,20
EventlistWrite; Timer 2; BreakOnVarEqu 3, 0
!this means it is raining if var not equal to 0
EventlistWrite; Timer 2; VariableSet 3,0.00
Eventlistwrite; Timer 2; FileExecute 201,Off
! check every 20 minutes for wind higher than 14 m/s
!set timer 3 to run every 20 seconds
EventlistWrite; Boot 5; TimerSet 3,20
EventlistWrite; Timer 3; TimerSet 3,20
EventlistWrite; Timer 3; BreakOnVarLess 4, 14
!this means the wind is higher than 14 m/s
Eventlistwrite; Timer 3; FileExecute 201,Off
! check every 20 minutes for wind gusts higher than 18 m/s
!set timer 4 to run every 20 seconds
EventlistWrite; Boot 5; TimerSet 4,20
EventlistWrite; Timer 4; TimerSet 4,20
EventlistWrite; Timer 4; BreakOnVarLess 6, 18
Eventlistwrite; Timer 4; FileExecute 201,Off
eventlistshow;
rwijbenga schreef:Hoppa ! Daar heb je zeker flink wat werk aan gehad, puik werk!
